Discussion topic: No signal pixelated screen
This message was authored by: Neil129
Hello, I've ordered the sky box office boxing the screen has been pixelated from the very start
Re: No signal pixelated screen
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
