Discussion topic: No signal TNT
This message was authored by: C_Easterbrook
No signal TNT
Afternoon all. All of my channels are working fine with the exception of TNT, which is getting no signal whatsoever. I have rebooted a couple of times and the problem persists. I have a subscription to TNT. Thanks very much
Re: No signal TNT
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
