Discussion topic: No satellite
This message was authored by: AlexProctor1
No satellite
My tv is saying no satellite
Re: No satellite
@AlexProctor1 if you mean 'no satellite signal ', the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
