Discussion topic: Viewing card on sky + is not paired to box
This message was authored by: Lisa433
Can't work out how to pair sky card to box
Re: Viewing card on sky + is not paired to box
@Lisa433 is this the same box that you've been using since October last year? If so, carrying out a New Install will re-pair your Viewing Card. Or call Sky and they'll can do it - don't let them tell you that you'll have to upgrade to Sky Q etc. You don't.
If this is a replacement box, you won't be able to pair it with your Viewing Card.
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q for New Install
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
