Discussion topic: No satellite signal
Message posted on 30 Nov 2025 03:08 PM
No satellite signal
How to get a satellite signal
Message posted on 30 Nov 2025 03:15 PM
Re: No satellite signal
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check / realign / repair / replace the dish, or perhaps the LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previous posted on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
Message posted on 30 Nov 2025 03:18 PM
No satellite signal on sky HD
Since the rain yesterday no satellite signal
Message posted on 30 Nov 2025 03:29 PM
Re: No satellite signal on sky HD
@L-Caz it's possible that rainwater has got into the cables from your dish. You might find the signal reappears once they've dried out. For a permanent solution, the cables will need to be replaced, if that's the issue. See @Daniel0210's post for how you go about it.
My first reply still applies.
Message posted on 30 Nov 2025 03:39 PM
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
- The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
- The Tuners in the sky box
- The input sockets on the Sky box
- The plugs on the cables
- The cables themselves
- The Sockets on the dishes LNB
- The dishes LNB has gone faulty for the connections the box is using
- You have plugged your Sky+ box into a dish that is only compatible with Sky Q
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
