Discussion topic: No satellite signal
This message was authored by: Lindsay25
No satellite signal
I have two boxes botg lost satelite signal. Internet us working xx
Re: No satellite signal
@Lindsay25
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
edit: your duplicate thread has been removed as you already have this one.
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
