Discussion topic: No satellite signal
This message was authored by: Gary221
No satellite signal
I have a message saying I have no satellite. Signal but my dish and cables are fine
Re: No satellite signal
@Gary221
Apparently not.
Sky no longer support Sky+ and Sky+HD. You'll need to employ a local satellite engineer at your own expense to check/repair/replace it.
If you have Sky Protect insurance through Domestic and General Insurance you can call them but a recent post suggested they wouldn't send an engineer - but did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
@Gary221 to be honest, it would be difficult to see from a glance whether or not your dish has moved slightly.  You need a technician with specialist equipment to check and adjust it for you.
