Discussion topic: No satellite signal .
This message was authored by Margaret74 This message was authored by: Margaret74
Picture freezing for 2 days. Have checked all connections. Turned off all connections several times. End up with same error. I have tv in bedroom working ok.
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No satellite signal .
@Margaret74
Almost certainly a dish misalignment. Although Sky themselves no longer support Sky+ and Sky+HD, if you have Sky Protect through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense to check it (or upgrade to Sky Q or change to Glass / Stream).
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by Annie+UK This message was authored by: Annie+UK
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox SeriesX
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
On average, new discussions are replied to by our users within 100 minutes
