Discussion topic: No satellite signal
Message posted on 23 Dec 2024 10:26 AM
No satellite signal
Tried restarting box and following onscreen instructions but still no signal
Message posted on 23 Dec 2024 10:28 AM
Re: No satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 23 Dec 2024 10:45 AM
@MeinirThomas123 Your duplicate thread has been removed
