Discussion topic: No satellite signal
This message was authored by: Davidnield
No satellite signal
My to says no satellite signal
Re: No satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
