Discussion topic: No satellite detected
This message was authored by: Poppy2016
I have 3 boxes but one says no signal being received while the others are ok, nothing blocking the dish etc
Re: No satellite detected
Please Note: Sky+ is now a legacy service that Sky are winding down
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
