Discussion topic: No satelite, box outdated
This message was authored by: Maria164
I have no channel on original sky box for over a year. Cannot cancel as I'm told I need it for my sky plus hd in my other room
Re: No satelite, box outdated
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Is this a very old SD only Sky Box?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
