Discussion topic: No signal on sky+
Message posted on 02 Dec 2025 06:54 PM
No signal on sky+
I have notice on screen my sky+ hd box is not getting a signal i.ve gone through all the instuctions restarted box and still same message
Message posted on 02 Dec 2025 07:14 PM
Re: No signal on sky+
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
- The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
- The Tuners in the sky box
- The input sockets on the Sky box
- The plugs on the cables
- The cables themselves
- The Sockets on the dishes LNB
- The dishes LNB has gone faulty for the connections the box is using
- You have plugged your Sky+ box into a dish that is only compatible with Sky Q
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
