Discussion topic: No satalite signal
This message was authored by: Caroline4669
No satalite signal
I have followed the online steps and on the signal section on settings the input lock indicator says not locked and input 1 network says null. Message says to get in contact.
Re: No satalite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
