Discussion topic: No Signal received
This message was authored by: PaulN1
No Signal received
I have followed all the onscreen protocols and am still not getting a signal.  This has been the case for over a week
Re: No Signal received
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
