Discussion topic: No signal to some channels
This message was authored by: Sheilaloo1
Can't get channel 5 or any of the associated 5 channels (ie 5 star)  or any of the British news channels.  Just says no signal. Or any radio stations .
Re: No signal to some channels
I'm assuming that's no satellite signal. The cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
