1
This discussion topic has been answered Discussion topic: No Satellitte signal
This message was authored by: JulieMurphy1
No Satellitte signal since the storms Friday, I've checked connection wires at back, switched off at mains, switched on again, nothing, checked dish which is just above ground all looks well ??
Re: No Satellitte signal
@JulieMurphy1
This dish might have moved slightly in the winds so if you are a Sky+ customer (where you have posted on here) you will need to find a local company to come out and look into this for you. If you do happen to have Sky Q then you can call Sky although beware that since the storms Sky are likely to be very busy with other similar issues being reported so there could be a delay on coming out to you.
@JulieMurphy1
