Discussion topic: Sky plus box not working no satellite signal
Message posted on 26 Jan 2025 02:45 PM
My sky box does not work. We have unplugged it several times to reset.
Thecl clock on sky says Thursday 1/1 time 12am which is incorrect and it is just a blue screen with message your ski + HD box isn't getting a satellite signal. Your recordings in the planner and the on demand service may still be available
Message posted on 26 Jan 2025 02:51 PM
Re: Sky plus box not working no satellite signal
I have had no reply
Message posted on 26 Jan 2025 02:53 PM
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 26 Jan 2025 02:54 PM
Message posted on 26 Jan 2025 03:01 PM
At the top of the Sky+ page is this…
On average, new discussions are replied to by our users within 100 minutes.
