Discussion topic: No Satellite Signal on Sky Box HD
Message posted on 04 Dec 2025 03:10 PM
Hi there,
My Sky plus box has stopped working.I have rebooted the box and checked connections but still no signal.Is there anything else I can try.
Martin
Message posted on 04 Dec 2025 03:48 PM - last edited: 04 Dec 2025 03:49 PM
Re: No Satellite Signal on Sky Box HD
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where your post now sits).
You'll need to employ a local satellite engineer at your own expense to;
- check / realign / repair / replace the dish,
- repair or replace the LNB if that's the problem
- check the cables for water ingress
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previous posted on here stated they wouldn't send an engineer - but they did offer the customer £ 65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
