Discussion topic: My sky keeps cutting out
This message was authored by: Martha8
My sky box keeps stopping
Avatar for Martha8
Level 0 icon
Re: My sky keeps cutting out
The sign says signal problem
No signal? Or no satellite signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
