Discussion topic: My sky+ box turned off yesterday evening and it won't turn back on, it keeps flashing the red and am
This message was authored by: Hibah
My sky+ box turned off yesterday evening and it won't turn back on again, it keeps flashing the red and Amber light. What do I do
Re: My sky+ box turned off yesterday evening and it won't turn back on, it keeps flashing the red an
Try turning off at the plug for 5 minutes or so. If the power light continues to flash after the box is restarted, I'm afraid the box has probably  failed and will need to be replaced.
What you have described is usually due to a hardware failure and will most likely mean the box needs replacing
You can either upgrade to Sky Q or purchase a secondhand Sky+HD box
Appropriate Sky+HD models are listed in the link below:
See question Q28 in my Sky Plus F⋅A⋅Q
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
