Discussion topic: My sky box isn’t working
This message was authored by: Joanne12341
My sky box has no signal
Re: My sky box isn’t working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
