02 May 2022 03:13 PM
Hello my Sky HD won't record anything and it's very slow I've reset the box but still the same
02 May 2022 03:23 PM
Posted by a Superuser, not a Sky employee. Find out moreHow did you reset the box? It needs to be switched off at the plug for at least 4 minutes.
02 May 2022 03:28 PM
Ok I did reset it but didn't leave it turned off for 4 mins it's strange it will download and record but won't record anything from the tv listings I will turn it off now and leave it for 4 mins thank you
02 May 2022 03:41 PM
Posted by a Superuser, not a Sky employee. Find out moreIt points to a problem with your Planner. If a simple restart doesn't fix it, the next step would be to rebuild your Planner as explained here: https://www.sky.com/help/home/sky-tv/sky-tv-plus/sky-plus-watching-sky-tv/sky-plus-recordings/articl...
02 May 2022 10:25 PM
Thank you mark I unplugged it for a while and it's now working as normal thank you
On average, new discussions are replied to by our users within 100 minutes
