Discussion topic: My mini skybox won't show RTE channels... Many other channels are working
Message posted on 22 Aug 2023 10:47 PM
Why is my mini sky box not showing RTE channels...? (many other channels are working)
Message posted on 22 Aug 2023 11:04 PM
Re: My mini skybox won't show RTE channels... Many other channels are working
Is this just a mini box issue or is the main box doing this too?
Message posted on 22 Aug 2023 11:07 PM
Just the mini box (and I have unplugged it at the mains/this did solve the problem in the past)
Message posted on 22 Aug 2023 11:10 PM
Is both your sky q main box and mini box up to date in terms of software?
Message posted on 22 Aug 2023 11:13 PM
I have no Sky Q... Sky + and mini box
Message posted on 22 Aug 2023 11:19 PM
Best thing to do is to call sky as this could be a satellite LNB issue
I'd also recommend upgrading to sky q as this could also be a software issue, and if any of the boxes have to be serviced it costs you £60 upgrading to sky q you get engineer visits free and also sky q box
I can't be 100% sure that's what's causing the issue, but seems to be like the mini can't communicate with the main box enough to get all the channels over
sky q may fix that
Message posted on 22 Aug 2023 11:28 PM
Sky Q doesn't work on my wall projector system... I have had sky engineers out twice in the past and they said sky Q could not be installed on my wall projector system
Message posted on 22 Aug 2023 11:32 PM
Ah right on the multi box you could try
go settings 001 select set its set as single cable mode
Message posted on 23 Aug 2023 08:51 AM
What happens when you tune to RTE? What's the error message?
