Discussion topic: Multiroom sky+
Message posted on 08 Apr 2024 12:50 PM
Multiroom sky+
How do I get rid of multiroom?
Message posted on 08 Apr 2024 12:52 PM
Re: Multiroom sky+
@Teetovanb
To remove part of your Sky Q/+ TV package you will need to contact Sky and give 31 days notice.
Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by calling Sky Ireland or writing in.
Message posted on 08 Apr 2024 01:22 PM
Re: Multiroom sky+
If you do cancel a Sky+ multiscreen box you will not be able to reinstate it at a later date as yoh would have to then upgrade to Sky Q if you want to watch Sky in another room.
