6
This discussion topic has been answered Discussion topic: can't reactivate my viewing card in Sky + after software update. Says go to Manage and TV setting.
This message was authored by: Blessington2
Mum got a software update last night now can't use her 23 year old viewing card.
It says intitialed it so off I went to quick/fix.com
Which gave me a message that finally ended up with
Go to Manage...... then TV...... and then TV settings......activate card.
I can't find TV settings in manage to take me to activate card.
Thanks in atnticpation for any help offered.
Re: can't reactivate my viewing card in Sky + after software update. Says go to Manage and TV settin
@Blessington2
It looks like your post here got caught in the spam filter so did you get this sorted or do you still need help ?
If you do try this:
Make sure your Sky viewing card is correctly inserted into the box.
Press Services on your Sky remote
Press 0, 0, 1, Select (setup should now be highlighted)
Scroll across to New Install
Press Select twice
@Blessington2
If you do try this:
Press Select twice
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
There are no software updates for Sky+ any more so she did not get an update
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
There hasn't been any software updates for Sky+ boxes for well over a year.
If your mum's box is stuck at  'initialising' it means it's not receiving a signal from her dish.
Avatar for Blessington2
Hi Mark Thanks for the reply She gets this message maybe every 6 months defintely every year. She has Sky+. And then you follow the message on Sky.com quickfix. And end up the little Sky picture a introduction playing disney or something.
But when you go to any of the channels the message is initialize your card with the box by going to Sky quickfix etc. Normally it was just a case of going to quickfix and put in all your numbers and everything is sorted in 5 minutes.
But not anymore that opportunity seems to have been removed off the app. Her signal bars are very good both are on 8/10 even 8.5/10. One is 9 one is 8.
Hi Body, Thanks for your help, yeah tried that did it for days hoping it work this time. But it doesn't.
Its weird that all the fall backs aren't working. She was a customer for 23 years with the full package. She is now inactivate herself.
I told her cancel Sky its gone too high tech now for her age group. I told her find a service you can speak with real people,
@Blessington2 is the message on screen 'initialising new Viewing Card'? If so, Sky have some help here: https://www.sky.com/help/articles/sky-box-initialising-new-viewing-card
