Discussion topic: Message saying viewing card not authorised
Message posted on 11 Apr 2025 08:00 PM
Sky isn't working. The message on screen says that the viewing card is not authorised
Message posted on 11 Apr 2025 08:06 PM
Re: Message saying viewing card not authorised
Message posted on 01 Jun 2025 07:49 PM
Message says viewing card not authorised
Message posted on 01 Jun 2025 07:50 PM
Please read the post immediately above yours.
Have you placed and perhaps cancelled, an order for Sky Q ?
Message posted on 22 Sep 2025 12:58 PM
I was going to upgrade..May, thought my sky box was faulty..infact was not so...was wall socket. Had electrician sorted socket. . canceled new packed within about 5 days. Yes was ok. They installed extra fast cable regardless.
- Then troubles started. Could not get catch up later could nor record . Have spoken to 3 separate sky personnel..they understood..would be sorted. Has not been done .
- I have stopped payment as told to last sky personnel. His reply was I should have had a new card.. which I haven't had nor knew about. He said one would be sent. No it has not.
- Get messages re make ppayment on regular basis.
- Have Been customer since November 2009.
- Dreadful treatment by them.
- Keep asking for help on the messages keep failing
Message posted on 22 Sep 2025 01:14 PM
@PP15 Sky won't talk to you until you sort out the overdue payments and reinstate your direct debit. Meanwhile you're still being charged.
You do need a replacement Viewing Card which should be easy to resolve.
