Discussion topic: No signal to sky box
Message posted on 22 Sep 2025 06:16 PM
Some tv channels not available
message says no satellite signal to box
sky channels are working
Message posted on 22 Sep 2025 06:29 PM
Re: No signal to sky box
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
