Discussion topic: Lost tv signal
This message was authored by: Andy197701
Lost tv signal
I'm having an extension built. Some builders have removed cladding which was surrounding my satellite dish. They haven't moved the position of the dish at all, nor have they touched the cabling, but now I'm receiving the error message that satellite signal has been lost. I've rebooted the sky boxes, but it hasn't fixed the issue. Please help!
Re: Lost tv signal
The dish has moved, it only needs to be moved a tiny amount for the signal to be lost
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Avatar for Andy197701
Re: Lost tv signal
Thanks. Is it something I can try and fix myself, by moving the dish?
Re: Lost tv signal
There is nothing stopping you 🙂
Re: Lost tv signal
@Andy197701 as @Annie+UK posted, you can try, but without specialist equipment, you'll be lucky to find the exact position necessary.
Re: Lost tv signal
Okay, cheers guys. Much appreciated.
