Discussion topic: Lost signal
This message was authored by: Tomglasock
Lost signal
I have lost TV signal
Re: Lost signal
@Tomglasock
Your dish might have moved slightly so you will have to find a local company to come out and look at this for you as Sky does not support Sky+ set up unless you are a Sky Protect customer.
Re: Lost signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
