Discussion topic: Locked satelite signal
This message was authored by: Amy+Lou80
My satelite signal is locked - what do I do?
Re: Locked satelite signal
You jump for joy as LOCKED is a good thing 👍
Avatar for Amy+Lou80
Hi @Annie+UK thank you for that! I still can't get all the channels I pay for, I'm only getting some of the free ones, not all of them 🤔
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
Is your viewing card paired to your box?
Try performing a New Install, which will re-pair your card
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
