21 Aug 2022 10:21 AM
My magic remote has just stopped working, when I have gone into the LG tv setting and gone to device connector none of the sky options work. I have a sky+HD box made by Amstrad.
Anyone else have this problem all of a sudden? Have you got it working again and if so how?
21 Aug 2022 01:55 PM
Posted by a Superuser, not a Sky employee. Find out moreIt's a pain but try Factory Resetting the LG
21 Aug 2022 11:29 AM
Posted by a Superuser, not a Sky employee. Find out moreThis youtube video might help
21 Aug 2022 12:05 PM
Thanks just tried that still not working, think issue is with the options on the device connecter screen, not the remote itself, no longer showing the sky+hd box as it used to be an option.
The remote itself works just not with sky.
21 Aug 2022 12:08 PM - last edited: 21 Aug 2022 12:10 PM
Posted by a Superuser, not a Sky employee. Find out moreTry deleting the Sky Box and then move it to a different HDMI, not seen this on my LG NanoCell
Has your TV had a firmware update recently?
HAve you tried turning off the sky box at the main for 5 minutes?
21 Aug 2022 01:49 PM
Done that. Interestingly the TV auto set new hdmi up as a TalkTalk device. This is my internet provider curiously. Still nothing when resetting it sky.
21 Aug 2022 04:44 PM
Will think about giving that a go. Thanks for the advice.
24 Aug 2022 07:06 PM
So reset TV. Tried all the sky options, no luck then tried Amstrad and this time it worked! We are go on the magic remote again. Thank you.
On average, new discussions are replied to by our users within 100 minutes
