Discussion topic: Keep losing signal
This message was authored by: Beryl1984
Keep losing signal
My sky keeps losing signal on all channels, why?
Re: Keep losing signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Beryl1984
This only started after I asked for my sky to be moved to new address on the 11th June, never had a problem before..
Coincidence. There's nothing Sky can do to make your dish setup provide a degraded signal.
