Discussion topic: Sky bix no signal and still initialising
This message was authored by: Stephen19691
I have a new sky + box and now I can't get a signal,when I go into tv guide it says its still initialising, nothing has changed apart from a new box
Re: Sky bix no signal and still initialising
There are no new Sky+ boxes. They haven't been manufactured since 2015/2016. Most likely the box is faulty, or the cable(s)  from the dish isn't  fitted quite right - it's very easy to bend the centre 'pin' of the connector if it's not lined up with the socket when pushing it in.
It's conceivable that there's a fault elsewhere with your dish setup, but that would seem unlikely if your previous Sky+ box was working ok.
If you previously had a Sky box the dish will have been altered to accommodate it, and is no longer compatible with Sky+.
