Discussion topic: ITV not working on hd box
This message was authored by: Fishing
Re: ITV not working on hd box
Not working how? Error message? Tell us more.
Avatar for Fishing
It's just said no signal by I can get itv+1
Avatar for Fishing
It says mini tv unavailable no satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
