Discussion topic: ITV channels not getting satellite signal
This message was authored by: Grumpy7
All my ITV stations through the Sky + HD box  say " your Sky + HD box isn't getting a satellite signal "
Re: ITV channels not getting satellite signal
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Grumpy7
Depending on where you are, we have just had a thunderstorm here and lost satellite signal on 103 (Sky Q) for a few minutes but okay now so if you're lucky it's weather related.
