19 Nov 2022 07:01 PM
I need 2 new cables for my sky plus HD boxes.. The cables that go from the wall to the dish imput 1 and 2 ports. Iv no idea if I can buy them or what they are called.
19 Nov 2022 07:37 PM - last edited: 19 Nov 2022 07:38 PM
Posted by a Superuser, not a Sky employee. Find out more@babyface17 You can buy extension cable such as https://www.amazon.co.uk/Satellite-Cable-Extension-Freesat-5METRES-BLACK/dp/B07NPNXZ5M#
19 Nov 2022 07:40 PM
Hi thank you for your reply. I see 4 attachments, I only need 3. One to go into the wall 2 for the back of the box.
19 Nov 2022 07:41 PM
19 Nov 2022 07:42 PM
19 Nov 2022 07:43 PM
Posted by a Superuser, not a Sky employee. Find out moreThat's a socket for a TV cable, not for a satellite connection.
19 Nov 2022 07:45 PM
Posted by a Superuser, not a Sky employee. Find out more@babyface17 Have you recently moved? Did you not book a home move with Sky?
19 Nov 2022 07:48 PM
@babyface17 wrote:
- It is what the sky man put in. Been a long while as iv had virgin for a few years. Can find where the wire went.
Not sure what has happened here. Sky don't install wall sockets.
19 Nov 2022 07:51 PM
The one in the bedroom is not like that. Its a wire coming in the wall. Cant understand what happened to the one in living room. I will look where the wire goes tomorrow when its light. Thanks for your help.
19 Nov 2022 07:53 PM
Posted by a Superuser, not a Sky employee. Find out more@babyface17 I suspect the wire coming through the bedroom wall is the one you need to connect to your Sky box. It's probably not currently connected to anything.
19 Nov 2022 07:54 PM
@babyface17 wrote:The one in the bedroom is not like that. Its a wire coming in the wall. Cant understand what happened to the one in living room. I will look where the wire goes tomorrow when its light. Thanks for your help.
Follow the cables from the dish to see where they enter the property.
On average, new discussions are replied to by our users within 100 minutes
