Discussion topic: I have sky+ and can’t get some channels
This message was authored by: Quadrophenia60
I can't get some channels on my Sky+, mainly the BBC & ITV ones but also channel 5 & MTV, I have tried the restart box option and it worked at first but not now. I can still download from the channels I can't get on the catch up tv but can't watch live, all the other channels are fine, is there anything I can try to correct this ?
Re: I have sky+ and can’t get some channels
What error messages, if any, are you getting when you tune to ITV?
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Quadrophenia60
It says "there is a technical fault with this channel " and if I go to BBC the message says "your Sky+HD box isn't getting a satellite signal " I wouldn't have any other channels if I wasn't getting a signal would I ?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I can't move to sky Q as I am in an apartment and when I asked the owners they wouldn't allow access to the dish so is the only way to call out a satellite engineer ?
If it's your own dish, yes.
If you 're connected to a communal dish,  speak to your landlord or their managing agents.
Thank you for your replies, really appreciate them. I have booked an independent satellite engineer to come and look at it on Friday
Do you have Sky+ box or a Sky+ HD box?
