Discussion topic: How do I upgrade to sky on demand
This message was authored by: RupertKrefting
Please can I upgrade to watch on demand
Re: How do I upgrade to sky on demand
@RupertKrefting
You should already have access to it as the Sky Signature package on your Sky+ box allows you to view catchup and boxset content in SD. If you also have the HD package on your account then you can access the content in HD.
You'll need a connection to your broadband service. If your Sky box has a WPS button on the front panel, it's wifi capable and you can connect over wifi. If it doesn't you'll need a cabled connection to your router, or a Mini (wifi) connector, which is a separate add-on bit of hardware. You might be able to find one on ebay.
Or perhanps more simply, upgrade to Sky Q or Sky Stream.
Some maybe subscribed to legacy Entertainment pack which did not include on-demand access🤔
