Discussion topic: Help getting replacement viewing card
This message was authored by: KATED3
Our sky account is active and being paid for but we have not received a replacement viewing card. A sky engineer came out and said that this was what was required to restore service but unable to find a way to ask for one.
Re: Help getting replacement viewing card
You won't be able to get a replacement viewing card for Sky+ any more. It's an obsolete service which Sky no longer sell or support.
You will most likely be encouraged to switch to Sky Q if you contact Sky.
@KATED3 are you sure ypu have Sky+? There's no engineer support for Sky+ boxes.
Avatar for KATED3
An engineer turned up to install sky q but said it wasn't worth it the equipment was too old and we needed a new viewing card instead
Why does your service need restoring, what happened ?
That from the engineer makes no sense. They should have replaced the dish and cables if they're unserviceable and the Sky Q box would be a different, up to date box anyway. That's all part of a normal Sky Q installation. There's no equipment that would be too old.
I'd be complaining to Sky.
How to make a complaint to sky: Sky Customer Complaints Code of Practice
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
