Discussion topic: He box
Message posted on 08 Jun 2025 02:22 PM
He box
Box is dead. Will not switch on.
Message posted on 08 Jun 2025 02:28 PM
Re: He box
Completely dead? No lights on the front panel?
Message posted on 08 Jun 2025 03:55 PM
Re: He box
Yes. Completely dead
Message posted on 08 Jun 2025 04:01 PM
Re: He box
If youi've tried a different mains socket and replacing the fuse in the plug, I'm afraid your Sky box has given up the ghost. and you'll need to upgrade to Sky Q or Sky Stream (unless you can get your Sky box repaired by a local repairer).
Message posted on 08 Jun 2025 04:04 PM
Re: He box
Do NOT consider purchasing a second hand box off sites such as eBay as it won't work (as you won't be able to pair your viewing card to it).
