Discussion topic: HBO max
This message was authored by: Aldoscott
HBO max
I can't get hbo max through my sky box
Re: HBO max
@Aldoscott you need Sky Q, Sky Stream or Sky Glass to be eligible, I'm afraid.
This message was authored by: Kayelaina
Re: HBO max
Hi. I have Sky+ and I can get HBO Max.  On the guide open catch up and on the left  hand side menu it shows HBO Max. Scroll down and select and the shows are there to download. I have jyst downloaded first episode of Lanterns.
Re: HBO max
Sky Plus does not have the ability to run ANY apps
There will be some content available in the On Demand / Box Office sections of your Guide depending on what subscriptions you have
To get full content access you usually need a newer service like Stream, Glass or Q
Annie..........
