Discussion topic: For the past 3 days my sky box says that there is no satellite signal
This message was authored by: Winston29
For the past 3 days my sky box has said that there is no satellite signal
Re: For the past 3 days my sky box says that there is no satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Winston29
Level 0 icon
This is no help i refuse to pay for a service that I have no access to if nothing is not done I will be cancelling my direct debit
How can my post be of no help!!!!!!
Cancelling your DD is not a smart move!!! Sky are providing you a service, it's YOUR equipment that is not receiving it correctly which means YOU need to get YOUR end fixed
@Winston29 it's a fault with your equipment, I'm afraid, as @Annie+UK posted. Cancelling your direct debit won't cancel your Sky subscription, and you'll continue to be charged for it, resulting in an increasing debt that Sky will seek to recover from you.
You could always accept Sky's offer and upgrade to SkyQ. Faults with your dish setup will be fixed at no additional cost, as part of the Sky Q installation..
Don't do that, you'll be in breach of contract and make matters worse.
As you've decided to stay with Sky+HD (as have I) rather than switch to Sky Q, unfortunately getting it fixed falls at your feet. You'll need to contact a local satellite company to get the issue diagnosed and fixed. Or contact Sky and switch to Sky Q, in which case they'll fix the issue as part of the switch over.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
That will result in a downgrade of your credit rating ... and debt collectors pursuing you🤔
If you no longer wish to be a Sky subscriber give your 31 days notice for subscription cancellation😉
