5
This discussion topic has been answered Discussion topic: Faulty card
This message was authored by: qwambo
Faulty card
The picture comes up with card not authorised.
Card number on screen is
This message was authored by: Annie+UK Answer
Re: Faulty card
You'll need to phone Sky to arrange a replacement card, if you don't already have one, as the one you have has been cancelled and can not be reactivated
Re: Faulty card
@qwambo have you previously ordered, then cancelled Sky Q?
Avatar for qwambo
Re: Faulty card
Yes, but a while ago.
Re: Faulty card
Re: Faulty card
@qwambo that's the reason, then. If you received a Viewing Card when you ordered Sky Q, you can use that, otherwise you'll need to request a replacement Card from Sky, I'm afraid. You don't have to switch to Sky Q or Stream.
Avatar for qwambo
Re: Faulty card
Thanks,  wife had put the new card on top of the box, didn't know it was there.
Up and running now.
