5
This discussion topic has been answered Discussion topic: Error message in sky + detected an issue with network settings
This message was authored by: RuthBA
Has anyone received this
Re: Error message in sky + detected an issue with network settings
@RuthBA
As your thread title refers to Sky+ I'll move your post to the Sky+ board.
@RuthBA
@RuthBA I've never seen this error reported before. Has your Sky+ box been connecting ok up to this point? As a matter of course, the first thing to try is restarting your Sky box, by switching it off at the plug for 4 minutes.
Avatar for RuthBA
Thanks seems ok for now
This message was authored by: Alan+at+Pboro
@RuthBA Hi, I have two SKY+ boxes, they do this every so often, my main one did this last Monday. It either sorts itself out or on my remote I:
1/ press Services
2/ select Settings
3/ Scroll across to network tap and press select
4/ Press red button to reset network connections
This usually sorts it, I hope that helps 🙂
Avatar for RuthBA
Thanks Alan if it happens again I will try that
