Discussion topic: 'Dead' Sky TV+ box
This message was authored by: Wi47
'Dead' Sky TV+ box
Hello.
My Sky + HD box is non responsive. It is 19 years.
Re: 'Dead' Sky TV+ box
Any lights on the front panel? Have you checked the fuse in the plug and tried a different power socket?
Avatar for Wi47
Hi.
There's one sad red light on the far right. I've turned everything on and off, changed the fuse etc.
@Wi47 it's a long time since I had a Sky+ box, and I can't remember what the light on the far right relates to! Assuming it's the power LED, you could try Sky's help here: https://www.sky.com/help/articles/sky-box-stuck-on-standby-sky-plus-hd
If that doesn't fix it, I'm afraid it's likely that your box has given up.
Yes, it's the power LED. Green - On, Amber - Standby, Red - Deep Sleep
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
