Discussion topic: Cutting off sky cable
This message was authored by: Elm123
Can I just cut off an old
multi room
cable?
Re: Cutting off sky cable
If you unscrew it from the dish then it is yours to do with as you see fit 🙂
This message was authored by: Tommy2
You own the cables once theyre installed and I know a lot of Sky/satellite and other services cables are isnatlled on the outside of hosues and can look quite messy, if you dont need it anymore then you can certainly remove it entirely. Just be careful when removing acble clips as they can be quite diffuclt to remove so make sure you use pliers as sometimes bits of mortar/render can come out. Also amke sure to fill in holes in the wall with mastic or filler, if not then cut the cable back directly to the wall.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
