11
This discussion topic has been answered Discussion topic: Connecting a new remote
This message was authored by: Millerman008
Just bought a new sky+ remote to replace a old one  that doesn't work properly .. trying to connect it to sky+ box , but I can't find the instructions to do it ?
This message was authored by: Mark39 Answer
Re: Connecting a new remote
A Sky+ remote should control a Sky+HD box without any configuration.
If you've just bought a new remote, I would have thought it would be a Sky+HD remote like the one shown here: https://www.pricerunner.com/pl/95-4578575/Remote-Controls/Sky-Sky-HD-Remote-Control-Compare-Prices
You can find the model number of your Sky box on the rear panel, I think.
It will be easier to help if you can clarify which remote and which Sky box.
Just press the Sky button on the remote as it should then start to operate your Sky+ box.
There's no need to connect a remote to a Sky+ box - it should just work. Unless you've bought a Sky+HD remote and want to use it with a Sky+ box (for example)?
Avatar for Millerman008
I believe it's a sky+hd box and a sky+ remote
The remote is a sky+HD remote and the system is a sky+hd box . I've check the back and there is no model name on it
New remote issius
Bought new sky+ remote but won't connect to Sky+hd box
Re: New remote issius
What happens after you press the big Sky button on it will it not operate your box then ?
No nothing woks ... didn't know if there was some sort of pairing setup I have to go through
You posted previously that you have a Sky+HD remote and a Sky+HD box. Either way, no pairing is needed. Either a Sky+ or a Sky+HD remote should control a Sky+HD box without any configuration.
If it doesn't work, it looks like either the box or the remote is faulty.
Could the age of the sky+hd box be a issius ... 8 years +
No, though it does increase the likelihood of it developing a fault.
