Discussion topic: Channel loss warning
This message was authored by: Yvonne38
A warning keep coming up saying channel will be lost by August. Although we have started a new package
Re: Channel loss warning
If you have HD then that message is wrong as it refers to some SD channels only
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
hi @Yvonne38
Which box do you have - do you have an HD box or still a very old SD only box ?
Did you by any chance get a second hand HD box ?
If you do have an HD box you shouldn;t  loose the channels in August and should not be getting the message but it is possible that SKY records are not correct and thus you are getting the nessage.
