Discussion topic: Channel 716 Sony SAB not working
This message was authored by: Disha2
Hi,
my sky box is fine but there is one channel that says no signal. 716 Sony SAB. I have restarted my box etc but still it doesn't work.
please help
Re: Channel 716 Sony SAB not working
@Disha2
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
▪️I AM NOT A SKY EMPLOYEE ▪️
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
